RCU Forums - View Single Post - BME 50 on Wagstaff, Ignition Problems??
Old 09-17-2004 | 10:41 AM
sedrick
Default RE: BME 50 on Wagstaff, Ignition Problems??
I had a similar problem with my BME 50 It turned out to be a faulty ignition module or damage to the module from vibration. check the output voltage from the module. It should be the same as the input from the battery. CH ignition can always fix it. Make sure you have the module well padded to prevent vibration damage.
