RCU Forums - View Single Post - Nitro Drifter?
Old 09-17-2004 | 12:09 PM
one-syk's Avatar
one-syk
Default RE: Nitro Drifter?
i drift with a nitro rs4 3 ss and my car is perfect for drifting..as long as you run it a little leaner then normal and you have plenty of air coming form all directions your car will be fine...i use rubber x pattern tires all the way around with 1.5 degrees of negative camber in the rear..thats all i use as far as drifting setup...everyonce in a while i add spring spacers in the rear just for a little extra slide...but i usually drift at night when the air and pavement are nice and cool...i have no problems at all except excessive inner rear tire wear
