RCU Forums - View Single Post - balance off - down thrust or try again ?
Old 09-17-2004 | 06:46 PM
David Cutler's Avatar
David Cutler
Default RE: balance off - down thrust or try again ?
It sounds like you have too much positive wing incidence.
Does the plane still climb when you cut the throttle? If so, you definitely have a problem with the wing / stabilizer alignment. You should pack up the trailing edge of the wing and try again.
If it doesn't climb when you cut the throttle, put some down thrust on the engine.
-David C.
