RE: Remember This Crash?
In places like the left wing tip, the covering was just peeled back a bit then the tip was rebuilt then I put the peeled covering back again so it looked normal...on the places where there is yellow, those required much more work and the covering being peeled back was just in the way so I just them off and pu the yellow trim sheet on top....it shows the bottom front of the fuselage with yellow because that whole thing was crushed....also the area below the right wing in the middle was the area that was sliced by the rubber bands....the right mid top of the wing looks normal with the yellow and red trim sheet apllied to it...that part was recovered by a leading edge and 1/16 balsa sheet..then with wood filler then sanded off to shape. That's all folks...
