Multiple Emails for new Posts?
Good question. I will look into it. At first glance it might be that when you subscribe to a thread and check the box to have email notification it sends you one whenever somebody replies. The second email would be in the user control panel where the option is set for email there too. In the user cp "Use 'Email Notification' by default?
Using this option emails you whenever someone replies to a thread that you have participated in"
If this is the case I could write some kind of duplication checking routine. The only fix until then would be to not check off the email notification box once you have participated in a thread knowing that your user cp option will email it for you. The other case when you subscribe to a thread but don't participate allows you to still get the email for that thread to watch the thread.
The check routine will be ideal so a user doesn't have to keep track though so I'll work on that.
RCadmin
