RCU Forums - View Single Post - Sig SE ARF Pushrods
Old 08-04-2002 | 08:28 PM
dickj's Avatar
dickj
Default Sig SE ARF Pushrods
I always use 4-40 steel rod instead of the supplied plastic or goldenrod ones. The 4-40 steel wont break as I have had both the expansion problem and the breakage problem with small ones. The weight is in significant and you can run the rods thru the outer tube of the plastic ones included in the kit. I have had the Sig SE and its a great flyer!
