RCU Forums - View Single Post - crossing wires on a pull-pull seup (?)
Old 09-18-2004 | 03:02 PM
Tall Paul
Default RE: crossing wires on a pull-pull seup (?)
I cross when I need to get rid of a big change in direction from servo to surface.
With nylon-coated cables I let them rub, with uncoated cables I put a spacer between so they can't rub on each.
What matters is the geometry at the servo horn and the surface horns.
How the cable gets there, just make it a smooth path.
