RE: 9C NOT RANGE CHECKING
Krysta, I used heavy-duty leads, which in conjunction with the servo leads, I twisted from end to end. I still had range problems, so I replaced the metal throttle pushrod and nylon clevis with a Ny-rod system. This apparently was the cause of my problem, as I can range check to 100'+ with no problem.
Thank you for your help. Saved me a lot of trouble! (and money)[sm=greedy.gif]
