RE: Engine crooked.
It depends, when you say to the left, do you mean as you're looking at the plane from the front, or as if you were sitting in the plane? You generally want some right thrust, that is, the engine should point slightly to the right, while looking straight down at the engine from overhead. Some down thrust is usually a good thing too.
Jesse
