RCU Forums - View Single Post - Engine crooked.
Old 09-20-2004 | 03:48 AM
tIANci's Avatar
tIANci
Default RE: Engine crooked.
Body ... that is why ships and planes call left and right as PORT (left of vehicle as you sit in the cockpit as the pilot) and STARBOARD (right of vehicle as you sit in the cockpit as the pilot).
I think one of the best ways to secure for a small plane is a lot of foam. I do that and it holds everything in place well IF there is a cavity for the whole thing to sit in. After that I will use some foam to cover the whole thing like a 'hatch'. When using foam be careful about the throttle linkage, don't let it strain the linkage if not your EPA will change.
