RCU Forums - View Single Post - CA Hinges installing
Old 09-20-2004 | 11:27 AM
glowplug
Default RE: CA Hinges installing
The problem is, the CA will harden BEFORE you get the hinge all the way in. It pretty much bonds on contact, so you either wont get the hinges into the control surface properly, or you won't get the control surface hinged to the wing or stab correctly, because the CA gives you absolutely NO working time.
