RE: U-Can-Do 3d 46?
ok guys, after reading thru eleven hundred some odd post, (took me about three days) I had to go buy a UCD 46. I have a question about a building point I'm at. I really didn't want to use the supplied CA hinges on the ailerons, and I had some dubro pinned hinges laying around. I figure I will feel a little more secure this way. My question is, should I use epoxy/thin CA when I slide them into the wood or none at all? I used a toothpick as a pin and no glue on a tester and it seemed to work pretty well. Just thought I'd get other peoples' opinion.
BTW.....I have an enya .80 lined up for it, WHAT DO YOU THINK????
THANKS!!!!
Joe
