RCU Forums - View Single Post - Phoneix Models Scanner - Surface Throws
Old 09-20-2004 | 11:42 PM
tIANci's Avatar
tIANci
Default RE: Phoneix Models Scanner - Surface Throws
Muza ... I use a lot of throw on mine ... the CG is at 3"-3.25" (very sensitive at 3.25"), if you are using a TT46 or OS46 then just set the engine to the back of the engine mount and it will be just right.
As for throws, rudder is on max, almost touching the elevator. Elevator about 3/4"-1", ailerons 3/4". I like my planes twitchy so that they can tumble fast on low speeds.
Standard is usually Ele - 1/2"-3/4"; Ail - 1/4"-1/2"; rudder - 1"
