RCU Forums - View Single Post - 3w-100 Starting Issues
Old 08-05-2002 | 11:35 PM
mglavin
My Feedback: (31)
Default 3w-100 Starting Issues
Bill
Sounds like after it warms and things grow, it sucks air form some place or another.
I would look at the reed block manifold, make sure there are gaskets both sides... Verify the surface is true with a straight edge.
Is this the new light-weight version engine?
Tighten all the bolts on the engine.
Look for obvious leaks at the cases and at the cylinder head to case areas. Should be a film of oil and or dirt if leaking.
As Helidude mentioned you may want to check the needle settings, I suspect this is not the problem though...
