RCU Forums - View Single Post - ThunderTiger Rare Bear
Old 09-21-2004 | 07:57 AM
  #340
Vampire
Default RE: ThunderTiger Rare Bear
Hi fellas,
Just a quick note to say I have attached a sketch showing my fuel tank relocate and mounting.
I'm been having issues posting pic's from my shop computer but will try to do so this evening of the tank relocate and my FX carb. needle moutning.
I had a chance to weigh my RB last evening and it came in at 11 lb. -5 oz which only puts it 5 oz. above max spec. weight. Not bad considering the power I have on board and that I have NO ballest weight in the airframe.
Nightchook, I have a good idea where you mounted your tank and I would suggest that you run your engine and IF you have issues, MOVE the tank forward vs. installing a pump as it just adds complexity to the fuel system and another item tha can fail.
BR
