RE: serious overheating problem
Stick Jammer is right. The cowl's the problem. It doesn't matter what the outside air temp is. If the engine is cowled it isn't seeing the outside air anyway. Take the cowl off when you ground run and make sure it has some cooling holes cut in it for when you fly.
