RCU Forums - View Single Post - How many Robart Hinges does it take?
Old 08-05-2002 | 10:49 PM
On Edge
Default How many Robart Hinges does it take?
Vince,
Is the gap tape shown below the one you recommend?
Is the hinge tape used the same way or as a hinge?
Jeff
Hinge Tape and Gap Seal
Hinge Tape is made of tough transparent mylar and comes in a 10-foot strip. Once you stick this stuff on, it won't come off, so be sure to align it properly before applying pressure.
Gap Seal is a stiff mylar that has adhesive only on one half of the tape. It is designed to seal the gaps in your wing at the surface hinges, yet allow for smooth movement of the hinge. This stuff works great, and we highly recommend it. It will stick to covering or natural wood finishes.
Hinge Tape (10 feet) $4.95
Gap Seal (10 feet) $4.95
