RE: First flights of GP Super Stearman w/ G26
I just drilled holes to match my mount on the 26 and ran me a wire through the hole and put the blind nut on it and bent the wire so the nut wouldnt come off and pulled it to where it would at least stick and then screwed a bolt in it with a lot of washers or larger nuts to jam it to the wood and once you mount the motor mount epoxy the blind nuts in place. I hope this helps. If not I will try and draw it. Let me know.
