RCU Forums - View Single Post - Fiberglassing problem
Old 08-05-2002 | 09:41 PM
Terry Holston's Avatar
Terry Holston
Default Fiberglassing problem
You can repair/fix your polyester or epoxy glass wet spots with CA.
Just use acetone to remove the wet spot, put a small patch of cloth in place and dribble a few drops of thin CA over the cloth. Block sand with 220 grit on a block and prime as needed.
Works for me.
