RCU Forums - View Single Post - Fiberglassing problem
Old 08-06-2002 | 06:59 AM
CobraJet's Avatar
CobraJet
Default Fiberglassing problem
Chris,
If you plan on priming over your glass job, and if you use a compatible polyester based primer (i.e. Duratec, etc.) can allow the uncured base resin to finally kick off and harden. It's worked for me on larger automotive fiberglass panels versus trying to sand/remove the uncured resin.
