PROBLEM WITH JR8411 SERVO SETUP
OK..... I AM A NEWBY AT GIANTS WITH DIGITAL SERVOS, I HAVE JUST PURCHASED A RTF 30% CARDEN AIRCRAFT CAP 232 WITH JR 8411'S ALL THE WAY AROUND. I'M USING A FUTABA 9CAP W/ 149DP PCM RX. EVERYTHING WAS A BREEZE DURING SETUP EXCEPT THAT I CAN'T GET MY RIGHT ELEVATOR TO CENTER WITH THE STAB. I CAN CENTER IT WITH TRIM ADJUSTMENT BUT IF I MOVE THE STICK DOWN AND RELEASE, INSTEAD OF COMING BACK TO CENTER IT STOPS JUST ABOVE. (NOTE- WHEN I MOVE THE STICK UP AND RELEASE IT WORKS FINE) ALSO IF I PUT PRESSURE ON THE SURFACE IT WILL "PULL" TO CENTER. I HAVE TRIED FIXING IT WITH SUBTRIM,EPA AND SO ON. NOTHING SEEMS TO WORK. DOES THIS MEAN I HAVE A BAD SERVO OR THAT I'M JUST WAY OUT OF MY LEAGUE? ANY HELP OFFERED WOULD BE FANTASTIC. THANKS, MIKE
PS. THIS IS THE MASTER SERVO PLUGGED INTO CH.2 THE SLAVE IS IN CH.8 ALSO I'M RUNNING THIS SYSTEM ON 6VOLTS WIDE OPEN NO REGULATORS COULD THAT BE MY PROBLEM?
