RE: Mc Culloch Chain Saw interferance
Couple things you can try...
Inspect the ignition wire VERY closely...look for any cracks in the rubbery parts...
Try wrapping the ignition lead very tightly with aluminum foil or aluminum tape.
I've had a bad receiver do the same thing your explaining as well make sure its wrapped in latex foam (vibes will kill a rx).
Good Luck!
CrazyHerb
