RE: Tiger 2 ---> Taildragger
If you're having to bend the nose gear back foward after every landing, that's a pilot problem. This would indicate that you are touching down with too much speed. You should practice your landings so that when you touch down, the plane doesn't want to fly any more. This should give you a slight nose-up attitude and keep the nose wheel intact.
