Lanier Edge 540T Thrust Line Question
Lee,
The vertical thrust line on mine is 3-3/4" above the bottom of the stock firewall. I measured by mounting the cowl and measuring the center of the hub cut-out projected back to the firewall with a square.
Yes, this line is the vertical thrust line.
Why draw two lines? You got it.
I can't answer your LG question.
-brad
