RCU Forums - View Single Post - Lanier Edge 540T Thrust Line Question
Old 09-09-2002 | 01:22 PM
bill white
My Feedback: (13)
Default Lanier Edge 540T Thrust Line Question
you have the modified gear set-up, which works fine, and is strong enough. Do not use canopy glue to attach the fiberglass cover over the landing gear. it won't hold. I used epoxy, after the cover came off, and it worked fine. BE VERY careful about using a pushrod for the elevator, unless you are using a small engine. I used a ST3250, which is overpowered, w/a arrow shaft pushrod, and on the second flight, while performing a split S, the elevators both developed flutter, and failed. I am replacing the plane, but will use dual servos in the tail, and if there is a resultant weight penalty, I will add the weight to the firewall.
Great flying plane, w/no bad habits that I detected, Bill
