shockflyer wing problem...need help
Hi,
I'm building an extra 330s and there seems to be a problem. Out of the two CF rods for the wings TE and LE, one is quite bent. I stuck the straight one first on the LE. Then I stuck the bent one on the LE, now my wing has this C shape dihedral. It's possible that the wing supports might straighten it a bit, but the wing tip's will sill be bent.
There's no way to replace it since I live in India, so either I could remove the TE and try to do some thing else, or finish the plane and hope it flies ok.
Any suggestions?
