RCU Forums - View Single Post - shockflyer wing problem...need help
Old 09-23-2004 | 06:54 PM
chronus
Default RE: shockflyer wing problem...need help
I used this metiod to straighten out my tail! i reckon would work on your wing. I use 4 inch wide clear packing tape and just run a strip of it under the wing from tip to end with the wing in the position you want to retain.the tape holds it straight no problem.
