Does Anyone Know If The SmarTech rc's off ebay are anygood ? here are some of the specs on one rc..
SOLID AND STURDY 2MM ALUMINUM CHASSIS
DISC BRAKE SYSTEM
ASSEMBLED CHASSIS
ORIGINAL MUFFLER AND AIR FILTER
FOUR WHEEL DRIVE SYSTEM WITH SHAFT DRIVE
OIL FILLED SHOCK ABSORBERS
DIFFERENTIAL WITH BUILT-IN FRONT AND REAR BEVEL GEARS
POWERFUL ENGINE EQUIPPED WITH SLIDE CARBURETOR AND PULL-STARTER
DOUBLE WISHBONE SUSPENSION ARMS WITH ADJUSTABLE WIDTH
ALUMINUM UPPER PLATE AND CHASSIS
HIGH IMPACT WHEELS
FRONT AND REAR BEARING DIFFERENTIALS
DISC-SHAPED BRAKE SYSTEM
FRONT UNIVERSAL JOINT SHAFT
80 CC FUEL PRESSURE TANK WITH PRIMER PUMP
NO-FLEX CHASSIS DESIGN FOR BETTER PERFORMANCE
HIGH TRACTION TIRES
SERVO SAVER LINKAGE SYSTEM
or if anyone justs wants to look at it here is the webling..
http://cgi.ebay.com/ws/eBayISAPI.dll...921851450&rd=1
Thanks For Looking And For You're Time
