RE: shockflyer wing problem...need help
I like the packing tape idea, probably what I would try. The down side to that is It adds weight and if you remove the tape the paint will come off with it. The Up side is you have a slightly tougher wing.
If your not in a hurry, You can order some foam from places like 3dfoamy.com and cut out another wing to replace the one thats bent.
