RCU Forums - View Single Post - Engine Break-in problems??
Old 09-24-2004 | 04:11 PM
Montague
Default RE: Engine Break-in problems??
Btw, that black stuff is often the first sign that something is coming loose on your engine. As Minn says, it's metal rubbing on metal.
If you see it in the future around the muffler, backplate, or head, it's a sure sign something is loose. Sometimes you'll see it appear around the engine mounting bolts, usually indicating that your engine is starting to work loose.
