RCU Forums - View Single Post - Quadra 35 electronic ignition help
Old 09-24-2004 | 05:38 PM
kevinf2501's Avatar
kevinf2501
My Feedback: (65)
Default Quadra 35 electronic ignition help
I have gotten a PT-19 that has a Quadra 35 in it with CH Ignition.
Does anybody have a manual or instructions on this particular ignition.
I need to know the following.
What voltage battery do I need to run?
I also need to find a wiring diagram.
There are 3 wires coming off the motor
*black, white and red. This goes direct to the ignition module
* green goes thru switch to ignition module
* black goes thru switch to ignition module
The switch thats on it is a 3 position toggle switch which I want to replace
with a 2 position Cermark switch with charging jack. I just want to make sure I wire it correctly.
The two wires (can see in the picture) are green and black and got to the switch. I need to make sure
I figure out which goes to positive and which to negative or if it even matters.
I have another lead that comes of the ignition which is a red and black and I assume this is the the battery lead.
If it is why would the switch not be between the ignition module and the battery instead of between the ignition module
and the motor?
Any help would be most appreciated
Kevin
ID:	176576   Click image for larger version
