At our field we usually have 3-4 guys up at a time. With the GWS single conversion receiver I got swamped. So I switched to the 555 for dual conversion. I no longer have any glitches.
This plane doesn't seem to mind the extra weight. I did take the plastic housing off.
I'm running one CS10 on aileron, it has plenty of authority even with them cranked up. It would be fun to have two servos. You could do such a tight loop the prop would hit the rudder
I can make it snap off elevator alone pretty easily, although I think part of that has to do with the flex in the foam elevator.
So Edman, did you get yours yet???
Happy flying all!
Scott H.
