RE: G2 USB Interlink Controller & FMS or others?
You'll have to Calibrate the joy stick before you can do anything else, then change the selections for the stick/channel.
Select Controls/Analog Control/Joystick Interface
Click on Mapping/Calibration and follow the calibration routine by pressing Calibrate in the right-hand box
After that, go to the left-hand box and change the Mapping. In my case, to fly Mode II, I had to use the following settings:
Rudder = 4
Elevator = 2
Aileron = 1
Throttle = 3
Yours may be different, but you can figure it out by seeing which stick controls which channel on the right. Just remember to hit OK when you're done. You should be OK.
By the way, if you read my previous msg (msg #2), you'll see that I didn NOT download the latest and greatest. That only had a few planes in it, and was sort of buggy. In fairness, it was advertised as a Beta version anyway.
I haven't done anything beyond that.
Did you download the Beta 7 file? That has about 10 different planes/copters to fly.
Let me know how you make out.
Bob
