RCU Forums - View Single Post - Interference with Gas engine
Old 09-27-2004 | 01:21 AM
mikenlapaz
Default RE: Interference with Gas engine
How did you get it over the plug wire with coil on one end and plug boot on the other? Last plug wire I tried to replace ended in failure as it was not screwed into the coil. Sodered then the epoxy case was poured. Hindsight[]
