RCU Forums - View Single Post - Tiger Moth ARF which one??
Old 09-27-2004 | 09:15 PM
V2PLUS10
Default RE: Tiger Moth ARF which one??
Ray44,
I have been flying a Dymond Tiger Moth for a couple (maybe three?)years now. I got the "antique silk" version because I felt a fabric covering was more scale, and painted it in the red/silver scheme. It is a really good flyer with an O.S. 91 four stroke and a 16-6 or 15-8 prop. The Dymond does not(or did not, maybe they are different now) come with windshields or flying wires, and there is no center tank in the upper wing. The landing gear needed to be modified to reduce the nose-over tendancy,(I cut the front braces and shortened them by about a half an inch, and then reconnected the ends with brass tubing and silver solder) . A friend has a GP moth and we flew together the other day. They are very similar in speed at about half throttle and both look good in the air. Really from a few feet you cannot tell the difference other than the color. No one around here has a Pacifc Aeromodels Moth but if I were to get another, that is what I'd buy....
The Moth also works wll on a set of GP floats. They are about 35" long, but I forget if they are .40size or the .60 size
Good luck!!
Randy
