RCU Forums - View Single Post - Icepoint build up.
Old 09-27-2004 | 10:34 PM
Eric.Henderson's Avatar
Eric.Henderson
Default RE: Icepoint build up.
Decided to make a variant of the mount.
Used two mounts to make one on the first version. Set the depth of first stand-off post on the lathe and cut them all to the same size. It came out pretty much to spec. Lined the spinner-backplate up with the nose ring.
Here are pictures of first mount. The idea is to provide a stronger rear support for the crankcase without adding a ton of weight.
ID:	177551   Click image for larger version
ID:	177552   Click image for larger version
ID:	177553   Click image for larger version
