RE: Please help with Rookiee flying :)
See if the rudder or ailerons if it has them turn both left and right from the neutral position. If not you need more control throw or movement in them or if it goes far left and not right then the control rods need adjusting.
If you do have good movement both ways then maybe putting some right thrust in the motor would work.
