RE: Icepoint build up.
Eric what did you use for the one pice rubber mount On the back of the new mount? I modifed my DB mount to more resemble the MK one with the top plate over the top of the
of the engine mount and that stiffened it up alot too. there is actally less movement on it than my last installation that had a gator RC firewall softmount.
I will try to get pics up tonight but I am almost done with it Just have to install the ailreions and servos on the wing and mount the belly pan and cutouts for the
hot air. I am also going to make a baffle for engine cooling on the belly pan. (you can see in the shot of the belly pan in the above pics how much room there is between
the head and the top of the pan. It can't hurt.
Then CG and final checkout. I hope to fly it wednesday if the weather and working on it pans out okay.
