RCU Forums - View Single Post - Zagi power problem
Old 09-28-2004 | 12:05 PM
Montague
Default RE: Zagi power problem
mounting a standard prop backwards does not make it push the air in the other direction, it just makes it push the air poorly in the same direction. So, if the current prop is pushing air in the correct direction, then it's not that.
Beyond that, I know very little about electrics. If you don't get an answer here, you might try in the electrics forum.
