RCU Forums - View Single Post - Help..what does
Old 09-28-2004 | 05:27 PM
David Cutler's Avatar
David Cutler
Default RE: Help..what does
How big is 6mm compare to one inch?
What does this mean 9x7 ?
There are 25.4 mm in one inch, so 6 mm is about 1/4 inch.
9x7 is a propellor size. It means it's 9 inches from tip to tip, and it will theoretically move forwards 7 inches per revolution. (Imagine a bolt turning one revolution in a nut, and the amount it moves axially is the pitch)
'9' is called the diameter, '7' is called the pitch.
So, a 16x4 is 16 inches from tip to tip, and it will move forwards (theoretically) 4 inches per revolution.
-David C.
