Digital Servo Programer ?
Good Day Mike,
I am finally into the digital world, they are great servos however I do have a problem with the programer? I am not sure if I am on glue or what here but when I try to adjust the centering and end points I have troubles. The way I read the insturctions is you set the certer and then adjust the throws at either end.. The centering works fine but when I set the end points for a given angle and plug the servo into the reciever I only get about 75% of the throw I dialed in. Yet when I set the fail safe location it goes to the setting perfectly.
Thanks in advance for your help, by the way the dual rates and end points in my transmitter are set to 100% so its not a rate issue. If I reset the servo I get full throw out of it. (I think about 65 degrees +/- comes to mind)
Take Care for now,
Riverdancer
