Hi Jim, thanks for your reply. If you look at the link go to the bottom of the page you will see in the bottom right the center point that I am talking about in the front of the plane. I see no easy way to find dead center as the fuse is curved anf if I just mesure across the fire wall for center it seems off center. Your method seemed to work fine but I just want to make sure I don't have any problems before I do the final epoxy. Thanks for all your help it is greatly appreciated.
http://www.theworldmodels.com/para/i...on/a099/p4.pdf
Robert
