Kangaroo 2 nose heavy???
I'm finishing my Roo 2, everybody was saying that it tend to came nose heavy. I'm using a Wren MW54 with wand starter so no starter on the nose of the engine. I've got the tray set about standard ( air valves, stearing, air brakes, retract servos, receiver) CG should be 100mm in front of the edge of the wing tube.
I'm using Robart 630 gears
I putted 2x 6v 1100mah nicad batts on the box already made for that at the end of the fuse. So i have to put the upper tank ( 4oz paper clunk) and the 3cells 1100mah nicad (pump batts)on the nose retract former to achieve the cg point. Is it normal??
When the Roo sits on his wheels, it's very easy to raise the nose(very little effort). is it normal???
