RCU Forums - View Single Post - Please Help Needle Idle setting
Old 09-29-2004 | 11:28 PM
TMooreATX
Default RE: Please Help Needle Idle setting
7.5 turns out on the LS to start and 3-4 turns out on the HS. This setting will get you started. If the LS needle is too lean the HS needle will have no effect whatsoever.
Once the engine idles pinch the fuel line and make sure that the engine takes 6-8 seconds BEFORE it speeds up, then set the HS needle to suit.
TM
