ORIGINAL: spawnxx2k
ORIGINAL: carrellh
The stick setup you describe is Mode 3.
Based on your follow up post, that's not what's creating the dual rates problem.
I believe your elevator and throttle servos are plugged into the wrong receiver channels.
I have a 6XAS, which is pretty similar to the 6XA.
No matter what 'stick mode' you choose, the servos should be plugged in as:
1 Aileron
2 Elevator
3 Throttle
4 Rudder
Swap the channels, set the 'stick mode' to mode 3, and you should be able to set up your dual rates.
If i switch the channels then my right stick will be elevator and left will be throttle. spring assemble is on the throttle side whick for me is the right stick
You stated in another post that you have your transmitter set to stick mode 4. That's part of the problem. The other part of the problem is that your servos are not plugged into the receiver correctly. You need to plug your servos into the receiver as listed above. This is true for all Futaba radios regardless of stick mode. Then set the stick mode to 3 in the software of the transmitter. I have a Futaba 6XAS and it is set up as stick mode 3. Throttle and rudder are on the right stick.
