RCU Forums - View Single Post - Need Advice... Replace Steerable Props?
Old 09-30-2004 | 04:00 PM
pompebled
Default RE: Need Advice... Replace Steerable Props?
Changing to a single motor set-up is certainly major surgery. (read Bryan's thread on converting a Hammer to 700 surface drive on offshore to get an idea of the work involved)
The boat will react quite different from the current two-motor set-up.
If it's going to be a lot faster, I can't say, as I have only converted single 550 motor boats to a 700 set-up.
The 14,4 V is the max for the two motor set-up, where as you can run a 700 motor on 12-14 cells.
If the boat runs free even 16 cells are possible.
Then it would definately be much faster (and a handful to control...).
Regards, Jan.
