RE: Did I get the right mount???
The AXIMP-1 is the mounting plate that takes place or is the exact duplicate of the plywood mount you would have to make. The AXIRRM is the one that I pictured and is a takes place of the plywood BUT it has the motor mount holes on it and it is more stream lined to cut down on drag. The one you ordered is fine.....the black aluminum bracket that comes with the mounting hardware for the AXI attaches to the carbon fiber mount you ordered. Use 3mm bolts and lock nuts to fasten it.
Dave
