RE: Is it time to ditch this plane for something else?
I believe any factory defects should be replaced!!.. Which means people
have to call the company and give them the true problems that exist with
the plane... That being said.....
I also believe.. Advance models will not take the abuse like a trainer, second
plane does and most War birds needs to come in a little "hot" which can lead to
abuse of the air frame if your not use to these models...
If it's a defect.... Call..... If you assisted in the problems.... Gotta bite the bullet...
