RCU Forums - View Single Post - 3W-24 ignition problem ?
Old 10-01-2004 | 02:07 PM
dovella
Default 3W-24 ignition problem ?
I have this engine for about two years. I have ran it for about 3 hours since I started to use it.
Lately I built my new plan and fixed it in. I went to the field and I could not start it at all.
The battery is 1400mA and was tested under load it came out Okay.
Then I took out the plug to check it with and got no results.(no SPARK )
I read a lot about ignition problems and realized that my sensor is probably the root cause for my problem.It probbably a coil sensor (???)
I unscrew it (the ignition unit )and tried to pass a magnet over the metal part that is molded in the black holder. no matter how close I was the ignition did not spark. Touching the metal with a magnet with the right pool did induce a spark.
DID ANYONE HAVE THIS IN THE PAST? WHAT WAS THE SULOTION?[sm=drowning.gif]
