RE: BME 50 on Wagstaff, Ignition Problems??
I had the same problem, intermittantly unable to start, due to a bad pulse switch (the little electronic part that faces the magnet in the crankshaft hub). If CH ignition cant be reached you might be able to get a replacement part from BME, but it would be best to talk to the fellow at CH on the phone so he can walk you through testing of your ignition system.
peter
